Hi, where do i turn on the stats to be output inside the rendered images of the hardware render ? Same way as i have it in the viewport turned on in the visibility options ?
Stats in Render Output
Re: Stats in Render Output
The necessary settings (including the enable-switch) can be found under "Slate" in the "Render Pass Property Editor"..
thank you
